Was du brauchst
Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
Slide the back cover off by pushing it to the left, away from the side that held the screws.
Remove the cover.
This is what the device should look like once the back cover panel has been removed.
Fast fertig!
Abschluss
