Zum Hauptinhalt wechseln
Sony Reader Touch Edition PRS-600 Motherboard Replacement
Was du brauchst
  1. Sony Reader Touch Edition PRS-600 Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Motherboard Replacement, Battery: Schritt 4, Bild 1 von 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Sony Reader Touch Edition PRS-600 Motherboard Replacement, Inner Casing: Schritt 6, Bild 1 von 1
    • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
  7. Sony Reader Touch Edition PRS-600 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Pry open the black casing to access the screw that is holding down the battery holder.
    • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
    • Lift the black inner casing and the battery holder out of the device.
    • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
  8. Sony Reader Touch Edition PRS-600 Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Using a Phillips head screwdriver, remove the one 1.4 mm screw holding in the motherboard.
  9. Sony Reader Touch Edition PRS-600 Motherboard Replacement: Schritt 9, Bild 1 von 2 Sony Reader Touch Edition PRS-600 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Using the flat end of the spudger, flip up the 4 latches holding down the thin, orange strips that connect the motherboard to the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports.
    • To disconnect the the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports pull each orange slip away from their corresponding latch.
  10. Sony Reader Touch Edition PRS-600 Motherboard Replacement: Schritt 10, Bild 1 von 2 Sony Reader Touch Edition PRS-600 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Lift the end of the motherboard closest to the memory cards and pull out.
Abschluss
Clemson, Team 1-4, Benson Fall 2014 Mitglied von Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 637
