Einleitung
This guide will show you how to disconnect and remove the main circuit board of the Alpha 65 camera. This requires using a Phillips #00 screwdriver, plastic opening tool, and tweezers. Be sure to keep track of all screws and parts removed from the camera.
Was du brauchst
Remove the two 4.0 mm Phillips #00 screws on the base of the camera.
Remove the 3.0 mm Phillips #00 screw on the hinge of the screen.
Remove the two 2.0 mm Phillips #00 screws on the bottom-right side of the screen.
Remove the two 2.0 mm Phillips #00 screws on the bottom-left side of the screen.
Use the plastic opening tool to gently pry the screen open around the entire screen.
Use a plastic opening tool to disconnect the silver wires from the screen's circuitry and completely remove the screen from the camera.
Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
Unscrew the 4.0 mm Phillips #00 screw on bottom of the left side of the camera.
Unscrew the 5.0 mm Phillips #00 screw near the top of the left side of the camera.
Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
Remove the two 4.0 mm Phillips #00 screws on the right of the camera that are located on the upper right side and under the "Remote" port flap.
Detach the right side panel with the remote and HDMI ports of the camera by gently pulling on the panel.
Use tweezers to remove the blue and orange ribbon connectors from their connection points pictured here.
Remove the four 3.0 mm Phillips #00 screws.
Remove the 5.0 mm Phillips #00 screw.
Use your finger to flip the switch that holds the dual ribbon connector in place.
Gently use tweezers to disconnect the dual ribbon connector and the thin blue ribbon connector to the right of it from the circuit board.
Use tweezers to disconnect the blue, gold, and brown ribbon connectors near the top of the camera.
Use a plastic opening tool to pop open the connector holding the next ribbon to the circuit board.
Use tweezers to disconnect the ribbon.
Use tweezers to unplug the blue adapter located at the top right of the circuit board.
Use either plastic opening tools or tweezers to unplug the white adapter located on the right side of the circuit board.
Gently lift the circuit board away from the camera and turn it over.
Use tweezers to disconnect the final two plugs and completely remove the circuit board from the camera.
12 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
I posted this link to a "Can't read SD card problem" below. On most SLTmodels apparently the SD card reader is part of the main circuit, and my local repair shop wanted $160 for labor (!) to swap out the part:
does anyone know if replacing the motherboard would fix a fried aperture lever control motor?
