Zum Hauptinhalt wechseln
Dieser Teardown ist keine Reparaturanleitung. Um dein Sony SRS-BTX300 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Start opening the battery panel by removing the two rubber seals.
    • Start opening the battery panel by removing the two rubber seals.
  2. Use a phillips tip screwdriver to open the battery panel.
    • Use a phillips tip screwdriver to open the battery panel.
  3. Lift up the panel and unplug the battery. Lift up the panel and unplug the battery.
    • Lift up the panel and unplug the battery.
  4. Under the battery there are two phillips tip screws. Remove them to continue to  the motherboard disassembly.
    • Under the battery there are two phillips tip screws. Remove them to continue to the motherboard disassembly.
  5. Use a spattle to lift up the front enclosure. Use a spattle to lift up the front enclosure. Use a spattle to lift up the front enclosure.
    • Use a spattle to lift up the front enclosure.
  6. Use a phillips screw driver to remove all the visibel screws. There should be 17 screws.
    • Use a phillips screw driver to remove all the visibel screws. There should be 17 screws.
  7. Gently pull down the bottom enclosure and remove it. Gently pull down the bottom enclosure and remove it.
    • Gently pull down the bottom enclosure and remove it.
  8. Use your fingers to remove the back enclosure. Unplug the cabels before removing it completely. Use your fingers to remove the back enclosure. Unplug the cabels before removing it completely. Use your fingers to remove the back enclosure. Unplug the cabels before removing it completely.
    • Use your fingers to remove the back enclosure. Unplug the cabels before removing it completely.
Raffael Anklin
1 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 28
Insgesamt: 56
