Was du brauchst
Start opening the battery panel by removing the two rubber seals.
Use a phillips tip screwdriver to open the battery panel.
Under the battery there are two phillips tip screws. Remove them to continue to the motherboard disassembly.
Use a phillips screw driver to remove all the visibel screws. There should be 17 screws.
Use your fingers to remove the back enclosure. Unplug the cabels before removing it completely.
2 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
Hmm you could try a few things:
- Disconnect and connect the batterie -> Observe the status LED if it charges (change colour or so…)
- Meassure the voltage accross the battery (min 3.0V or more)
- Check the connection between batterie and the PCB
Tahnk you for your answer.
The LED is becomming red as it is charging, and after a few seconds it turns of, like it is charged already. But when the power cord is disconnected, the speaker dies.
I will try to open it and check the connections between batteries and PCB, also measure the voltage of the batteries and keep you posted. Weird is that I bought two sets of batteries and it does the same with each one. Unforntunately, I do not have the old battery anymore, because I have dissasemble it because I tought it is not good anymore, but apparently the batteries work fine.
Thank you again :)
On my SRS-BTX-300 the Audio in function including its button has stopped working. Pressing the volume button disconnects BT connection. I have Reset speakers several times to no avail. Any suggestions will be greatly appreciated
