Zum Hauptinhalt wechseln
Sony SRS-X3 Auxiliary Port Replacement
Was du brauchst
  1. Sony SRS-X3 Auxiliary Port  Replacement, Auxiliary Port Replacement: Schritt 1, Bild 1 von 1
    • Remove the 6 philips head screws using the screwdriver and the PH1 bit
  2. Sony SRS-X3 Auxiliary Port  Replacement: Schritt 2, Bild 1 von 1
    • Remove 5 philips head speakers holding in the battery and the green circuit board. 2 screws holding in the battery and 3 holding the circuit board.
  3. Sony SRS-X3 Auxiliary Port  Replacement: Schritt 3, Bild 1 von 1
    • Pick out the battery pack and the green circuit board so that you can see the ribbon wire and the wire running from the battery pack to the circuit board.
  4. Sony SRS-X3 Auxiliary Port  Replacement: Schritt 4, Bild 1 von 2 Sony SRS-X3 Auxiliary Port  Replacement: Schritt 4, Bild 2 von 2
    • Remove the ribbon wire and the connector coming from the battery pack to the circuit board.
    • These connectors will not easily pull out, so you might have to give them a tug. They aren't very fragile, so don't worry about shredding them.
    • After this step, simply insert a new circuit board and you're done! Reassemble the speaker and start jamming!
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Where did you buy the circuit board?
David Alvarez - Antwort
bad repair doesn't actually show replaceing port just circuit board and no info where to buy one.
munchy 22 - Antwort
Hi Andrew,
Can you tell me where I can purchase a replacement circuit board? I’m having trouble finding it online.
Part number is SONY 40BKB537U-CNF2G .
Thanks!
Julie Miller - Antwort
Where can I buy the circuit board and if you want me to buy it from you fine but tell us or tell me
Thanks
Jose reyes - Antwort
Donde puedo conseguir esas refacines
enriquereynahernandez423 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 1,818
