Zum Hauptinhalt wechseln
Sony SRS-X3 Battery Replacement
Was du brauchst
  1. Sony SRS-X3 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the 6 philips head screws using the PH1 bit.
  2. Sony SRS-X3 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the 3 philips head screws holding in the green circuit board
  3. Sony SRS-X3 Battery Replacement: Schritt 3, Bild 1 von 1
    • Unclip the battery pack and replace it with another one.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Can you give the battery # on this please
Dan Clark - Antwort
Good instructions. I had one problem when removing the green circuit card. The ribbon cable came out. On mine there was a small black retention bar that I flipped open to allow the ribbon cable to reinsert, then I returned the retention bar back down to secure the ribbon cable in place. It worked fine after that.
Harpo - Antwort
It would be nice if the article addressed the 6 rubber pads that cover the screws. There doesn't seem to be a way to remove them without damaging them, and you need them in order to use the speaker without it rattling and moving about from vibrations.
Peter Nosko - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 21
Letzte 30 Tage: 117
Insgesamt: 6,985
