Zum Hauptinhalt wechseln
Sony SRS-X5 Bluetooth Replacement
Was du brauchst
  1. Sony SRS-X5 Bluetooth Replacement, Battery: Schritt 1, Bild 1 von 1
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 Bluetooth Replacement: Schritt 2, Bild 1 von 2 Sony SRS-X5 Bluetooth Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Bluetooth Replacement: Schritt 3, Bild 1 von 1
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 Bluetooth Replacement, Speaker: Schritt 4, Bild 1 von 1
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 Bluetooth Replacement: Schritt 5, Bild 1 von 1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 Bluetooth Replacement: Schritt 6, Bild 1 von 2 Sony SRS-X5 Bluetooth Replacement: Schritt 6, Bild 2 von 2
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 Bluetooth Replacement: Schritt 7, Bild 1 von 3 Sony SRS-X5 Bluetooth Replacement: Schritt 7, Bild 2 von 3 Sony SRS-X5 Bluetooth Replacement: Schritt 7, Bild 3 von 3
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
  8. Sony SRS-X5 Bluetooth Replacement, Bluetooth: Schritt 8, Bild 1 von 2 Sony SRS-X5 Bluetooth Replacement, Bluetooth: Schritt 8, Bild 2 von 2
    • Unplug the cord connected to the motherboard by squeezing the plastic sides.
  9. Sony SRS-X5 Bluetooth Replacement: Schritt 9, Bild 1 von 1
    • Gently tug on the plastic ribbon connected to the bottom side of the speaker to unplug it.
  10. Sony SRS-X5 Bluetooth Replacement: Schritt 10, Bild 1 von 1
    • Remove the motherboard.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Muy bueno! Gracias Jeffrey!.
LUIS CARLOS MEJIA DIAZ - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 1,983
