Einleitung
This guide will show how to replace the speaker component of the Sony SRS-X5.
Was du brauchst
To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
Remove the bottom panel of the speaker.
Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
Remove the battery.
To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
5 weitere Personen haben diese Anleitung absolviert.
10 Kommentare
Help :)
Where can i buy a New speaker ?
Best regard Olav
lol everywhere i go to find the replacement speaker i find more people trying to find it…. really want to fix my speaker..ffs
is there not a single soul that know the answer, why is this so hard to find out. im starting a company in loose speaker cones
Excellent!!! Thank you : )
Many thanks. Now I just need to find a replacement speaker!
