Einleitung
If your Sony SRS-X55 speaker won't play sound from the auxiliary jack, replacing the I/O board may resolve the problem.
Was du brauchst
Remove the six screw covers with a spudger.
Remove the six 11 mm Phillips screws from the bottom panel.
Remove the bottom panel of the speaker.
Remove the two Phillips screws from the I/O board.
Remove the front panel to the speaker by pushing on the two tabs in the corners.
Disconnect the ribbon cable from the I/O board.
Carefully remove the I/O board from the speaker.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
