Zum Hauptinhalt wechseln
Sony SRS-X55 Input Board Replacement
Was du brauchst
  1. Sony SRS-X55 Input Board Replacement, Input Board: Schritt 1, Bild 1 von 1
    • Locate the six 9 mm screws on the bottom of the SRS-X55 and remove them using a Phillips head #2 screwdriver.
  2. Sony SRS-X55 Input Board Replacement: Schritt 2, Bild 1 von 2 Sony SRS-X55 Input Board Replacement: Schritt 2, Bild 2 von 2
    • Insert a plastic spudger at the seam of the bottom panel and remove it from the rest of the speaker.
  3. Sony SRS-X55 Input Board Replacement: Schritt 3, Bild 1 von 3 Sony SRS-X55 Input Board Replacement: Schritt 3, Bild 2 von 3 Sony SRS-X55 Input Board Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Locate the battery plug and remove it using a pair of tweezers.
  4. Sony SRS-X55 Input Board Replacement: Schritt 4, Bild 1 von 3 Sony SRS-X55 Input Board Replacement: Schritt 4, Bild 2 von 3 Sony SRS-X55 Input Board Replacement: Schritt 4, Bild 3 von 3
    • Locate the two 3.5 mm screws on the bottom of the I/O board and remove them using a Phillips head #2 screwdriver.
  5. Sony SRS-X55 Input Board Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic spudger to remove the I/O board from the speaker body.
  6. Sony SRS-X55 Input Board Replacement: Schritt 6, Bild 1 von 2 Sony SRS-X55 Input Board Replacement: Schritt 6, Bild 2 von 2
    • Insert a plastic spudger into the seam of the metal speaker cover and pry it downward until it releases from the speaker body.
  7. Sony SRS-X55 Input Board Replacement: Schritt 7, Bild 1 von 2 Sony SRS-X55 Input Board Replacement: Schritt 7, Bild 2 von 2
    • Locate the eight 8.9 mm screws on the face of the speaker assembly and remove them using a Phillips head #2 screwdriver.
  8. Sony SRS-X55 Input Board Replacement: Schritt 8, Bild 1 von 2 Sony SRS-X55 Input Board Replacement: Schritt 8, Bild 2 von 2
    • Insert a plastic spudger underneath one of the tabs located on the front of the speaker assembly and gently raise the speaker assembly above the rest of the speaker.
    • Continue to the next step before attempting to lift the speaker assembly from the rest of the speaker entirely to avoid damaging internal wires.
  9. Sony SRS-X55 Input Board Replacement: Schritt 9, Bild 1 von 3 Sony SRS-X55 Input Board Replacement: Schritt 9, Bild 2 von 3 Sony SRS-X55 Input Board Replacement: Schritt 9, Bild 3 von 3
    • Locate the two wire connections as shown underneath of the speaker assembly and unplug them using a pair of tweezers.
  10. Sony SRS-X55 Input Board Replacement: Schritt 10, Bild 1 von 1
    • Locate the wire connecting the motherboard and the input board under the top panel of the speaker and remove it using a pair of tweezers.
  11. Sony SRS-X55 Input Board Replacement: Schritt 11, Bild 1 von 3 Sony SRS-X55 Input Board Replacement: Schritt 11, Bild 2 von 3 Sony SRS-X55 Input Board Replacement: Schritt 11, Bild 3 von 3
    • Insert a plastic spudger into the seam at the edge of the top panel and gently pry it away from the rest of the speaker.
    • The spudger can be inserted laterally into the opening created by the spudger and slid along the top as shown to remove the panel in a single motion.
  12. Sony SRS-X55 Input Board Replacement: Schritt 12, Bild 1 von 1
    • Locate the three 4.5 mm screws on top of the speaker input board and remove them using a Phillips head #2 screwdriver.
  13. Sony SRS-X55 Input Board Replacement: Schritt 13, Bild 1 von 3 Sony SRS-X55 Input Board Replacement: Schritt 13, Bild 2 von 3 Sony SRS-X55 Input Board Replacement: Schritt 13, Bild 3 von 3
    • Insert a plastic spudger underneath the edge of the input board and gently pry it away from the rest of the speaker.
Abschluss
Chris Sparzo
351 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-3, Baechle Spring 2017 Mitglied von IUPUI, Team 2-3, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G3
3 Mitglieder
3 Anleitungen geschrieben
2 Kommentare
Where I can find a new input board for my srs-x55??
luc belair - Antwort
I want to buy the sony input board.. can u pls help me on this
prafulpu - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 945
