Zum Hauptinhalt wechseln
Sony SRS-X55 Motherboard Replacement
Was du brauchst
  1. Sony SRS-X55 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Sony SRS-X55 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Sony SRS-X55 Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
  2. Sony SRS-X55 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
  3. Sony SRS-X55 Motherboard Replacement, Speaker Panel: Schritt 3, Bild 1 von 1
    • Remove the speaker grill by pushing on the two tabs in the corners.
  4. Sony SRS-X55 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  5. Sony SRS-X55 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 3 Sony SRS-X55 Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 3 Sony SRS-X55 Motherboard Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Flip open the speaker panel to access the interior of the device.
    • Carefully unplug the three cables and one ribbon connector connected to the motherboard.
    • Remove the motherboard.
Abschluss
Jordon McDuffie
101 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 3,198
