Einleitung
This Audio System is the model SRS-XB30. One of the common malfunctions is the charging port. This guide will show you step by step instructions on how to replace the charging port.
Was du brauchst
To remove the speaker grill, insert the big spudger underneath it in each corner.
With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
Remove each of the four corner screws (15.0 mm long).
Unclip the four wire connectors (that are attached to the speaker lid).
Disconnect the thin yellow wire (attached to the speaker lid) from its port.
Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
Locate the blue film attached to the circuit box containing the charging port.
Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
Locate the circuit box containing the yellow charging port.
Remove the circuit box from any attachments connecting it to the speaker.
4 weitere Personen haben diese Anleitung absolviert.
8 Kommentare
Hi where I can find new circuit box?
That’s right , at the very beginning it says that no parts are needed , what about the new charging port where can we get it?
I am incredibly curious, and a little bit excited, to hear what it is that was going through your mind at the start of this in comparison to when you reached the end? The exact moment that the very title of this article says very clearly the word “replacement” and then to see the amazing luck of the mistaken omission which read “No Parts Required” only to then be let down again when you realized that a part was in fact required. After-all it is called “Charging Port Replacement” so I’m sure you probably healed up pretty quick from the heartbreak you suffered.
Very clear instructions, thanks.
Any idea where I can find a new charging port for my speaker? Can’t find anything on the internet..
Thanks by advance
Dries
