Was du brauchst
To remove the speaker grill, insert the big spudger underneath it in each corner.
With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
Remove each of the four corner screws (15.0 mm long).
Unclip the four wire connectors (that are attached to the speaker lid).
Disconnect the thin yellow wire (attached to the speaker lid) from its port.
Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
Locate the blue film attached to the circuit box containing the charging port.
Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
Locate two silver screws (9mm) attached to each speaker shield.
Remove the two silver screws on each speaker shield using the screwdriver with the PH1 head.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Are there any replacement drivers for this or the XB31?
