Zum Hauptinhalt wechseln
Sony SRS-XB40 Speaker Replacement
Was du brauchst
  1. Sony SRS-XB40 Speaker Replacement, Speaker Assembly Replacement: Schritt 1, Bild 1 von 1
    • Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
  2. Sony SRS-XB40 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the four T-8 screws (15 mm long) from the black speaker face.
  3. Sony SRS-XB40 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Pry the two rubber end pieces loose enough to pry off two pieces of the long plastic casing from the speaker body using a metal spudger.
  4. Sony SRS-XB40 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Pry the two remaining rubber pieces of the casing completely away from the body of the speaker with the same metal pry tool.
  5. Sony SRS-XB40 Speaker Replacement: Schritt 5, Bild 1 von 2 Sony SRS-XB40 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Once you have removed the outer blue casing, four T-8 screws (15 mm long) will be revealed on each corner. After removing these screws, simply pull the top part of the speaker way from the body to get the the inner part of the speaker.
  6. Sony SRS-XB40 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Once you have gotten to the internal parts of the speaker, there are seven wires connecting the speaker plate to the body of the speaker. Pinch the release tabs at the top of each of the four main wires to remove them.
  7. Sony SRS-XB40 Speaker Replacement: Schritt 7, Bild 1 von 3 Sony SRS-XB40 Speaker Replacement: Schritt 7, Bild 2 von 3 Sony SRS-XB40 Speaker Replacement: Schritt 7, Bild 3 von 3
    • Simply pull the thin wires on each side to remove them from their attachment points.
    • Remove the final red and black wire by gently pulling it apart.
    • This will ultimately detach the speaker plate from the base.
  8. Sony SRS-XB40 Speaker Replacement, Speaker: Schritt 8, Bild 1 von 2 Sony SRS-XB40 Speaker Replacement, Speaker: Schritt 8, Bild 2 von 2
    • After you have gotten the speaker plate off of the main body of the speaker, there will be two PH1 10mm screws that hold on the speaker.
    • Using the screwdriver and PH1 head from your toolkit, unscrew the 2 screws and place them to the side.
  9. Sony SRS-XB40 Speaker Replacement: Schritt 9, Bild 1 von 1
    • Now your speaker is free from the speaker plate and you can replace the broken or faulty one with a new one.
    • Your speaker replacement is now done.
Abschluss
Zack Coker
379 Reputation
2 Anleitungen geschrieben
4 Kommentare
Where can i purchase a replacement speaker?
Evan Mocke - Antwort
Where do I get the replacement speaker?
Elijah allen - Antwort
I broke my speaker case. It’s the black, plastic protective case that is in front of the speaker. Where can i get a new replacement part?
Lilee Foster - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 25
Insgesamt: 4,315
