Zum Hauptinhalt wechseln
Sony SRS-XE200 Microphone Replacement
Was du brauchst
  1. Sony SRS-XE200 Microphone Replacement, Speaker Assembly: Schritt 1, Bild 1 von 2 Sony SRS-XE200 Microphone Replacement, Speaker Assembly: Schritt 1, Bild 2 von 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Microphone Replacement: Schritt 2, Bild 1 von 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Microphone Replacement: Schritt 3, Bild 1 von 2 Sony SRS-XE200 Microphone Replacement: Schritt 3, Bild 2 von 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Microphone Replacement: Schritt 4, Bild 1 von 2 Sony SRS-XE200 Microphone Replacement: Schritt 4, Bild 2 von 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Microphone Replacement, Battery: Schritt 5, Bild 1 von 3 Sony SRS-XE200 Microphone Replacement, Battery: Schritt 5, Bild 2 von 3 Sony SRS-XE200 Microphone Replacement, Battery: Schritt 5, Bild 3 von 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Microphone Replacement: Schritt 6, Bild 1 von 3 Sony SRS-XE200 Microphone Replacement: Schritt 6, Bild 2 von 3 Sony SRS-XE200 Microphone Replacement: Schritt 6, Bild 3 von 3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
  7. Sony SRS-XE200 Microphone Replacement, Charging Port: Schritt 7, Bild 1 von 2 Sony SRS-XE200 Microphone Replacement, Charging Port: Schritt 7, Bild 2 von 2
    • Remove the charging port.
  8. Sony SRS-XE200 Microphone Replacement, Microphone: Schritt 8, Bild 1 von 3 Sony SRS-XE200 Microphone Replacement, Microphone: Schritt 8, Bild 2 von 3 Sony SRS-XE200 Microphone Replacement, Microphone: Schritt 8, Bild 3 von 3
    • Remove the two 0.8 mm screws connecting the motherboard to the microphone with a Phillips #1 screwdriver.
    • Remove the microphone.
  9. Sony SRS-XE200 Microphone Replacement: Schritt 9, Bild 1 von 1
  10. Sony SRS-XE200 Microphone Replacement: Schritt 10, Bild 1 von 2 Sony SRS-XE200 Microphone Replacement: Schritt 10, Bild 2 von 2
  11. Sony SRS-XE200 Microphone Replacement: Schritt 11, Bild 1 von 3 Sony SRS-XE200 Microphone Replacement: Schritt 11, Bild 2 von 3 Sony SRS-XE200 Microphone Replacement: Schritt 11, Bild 3 von 3
    • Remove the microphone from the case of the speaker.
    • Replace the microphone.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 202
