Zum Hauptinhalt wechseln
Sony SRS-XE200 Motherboard Replacement
Was du brauchst
  1. Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: Schritt 1, Bild 1 von 2 Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: Schritt 1, Bild 2 von 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Motherboard Replacement: Schritt 3, Bild 1 von 2 Sony SRS-XE200 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Motherboard Replacement: Schritt 4, Bild 1 von 2 Sony SRS-XE200 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 3 Sony SRS-XE200 Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 3 Sony SRS-XE200 Motherboard Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the cord connecting the charging port to the motherboard.
  7. Sony SRS-XE200 Motherboard Replacement: Schritt 7, Bild 1 von 3 Sony SRS-XE200 Motherboard Replacement: Schritt 7, Bild 2 von 3 Sony SRS-XE200 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the two 0.8 mm screws attaching the motherboard to the case compartment with a Phillips #1 screwdriver.
    • Detach the motherboard from the case compartment.
Abschluss
Ein Kommentar
Hy please I m from morrocco i need a matherbeard a have a speaker but not work i d'not no way i need help plz
Abdou Abdou - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 43
Insgesamt: 390
