Einleitung
This guide will teach you how to safely replace the battery for the Sony Smart Watch SW2.
Was du brauchst
Detach the smart watch from the band by pushing on the back of the watch housing.
Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
Lift one side of the battery up carefully. There is a thin black circuit adhered to the back of the battery that connects to the motherboard and the charger.
Push the black piece down while very carefully pulling the battery off. Work your way around without lifting the black piece up too much.
Once the battery is free from the frame adhesive, desolder the black and red battery wires.
Remove the battery.
To reassemble your device, follow these instructions in reverse order after the battery is replaced.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
HI
please from where can i get the battery i want new one you know any website sell this battery
thanks
I think AliExpress has some compatible batteries. I may order one too.
