Zum Hauptinhalt wechseln
Sony TC-WE825S Power Button Replacement
Was du brauchst
  1. Sony TC-WE825S Power Button Replacement, Power Button: Schritt 1, Bild 1 von 3 Sony TC-WE825S Power Button Replacement, Power Button: Schritt 1, Bild 2 von 3 Sony TC-WE825S Power Button Replacement, Power Button: Schritt 1, Bild 3 von 3
    • Unscrew the 8mm Phillips head screws from the left and right sides of the cassette player.
  2. Sony TC-WE825S Power Button Replacement: Schritt 2, Bild 1 von 3 Sony TC-WE825S Power Button Replacement: Schritt 2, Bild 2 von 3 Sony TC-WE825S Power Button Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the 8mm Phillips head screw from the back of the cassette panel. Remove the cover.
  3. Sony TC-WE825S Power Button Replacement: Schritt 3, Bild 1 von 3 Sony TC-WE825S Power Button Replacement: Schritt 3, Bild 2 von 3 Sony TC-WE825S Power Button Replacement: Schritt 3, Bild 3 von 3
    • Locate the power cord connection and disconnect it. To remove it, press down on the plastic tab and slowly slide it out of the socket.
  4. Sony TC-WE825S Power Button Replacement: Schritt 4, Bild 1 von 2 Sony TC-WE825S Power Button Replacement: Schritt 4, Bild 2 von 2
    • Locate the cords that are connected to the power button. Remove the connection by tugging on the cords gently, releasing them from the main PC board.
  5. Sony TC-WE825S Power Button Replacement: Schritt 5, Bild 1 von 1
    • Unscrew all five 7.5mm Phillips head screws from the PCB (printed circuit board) behind the power switch.
  6. Sony TC-WE825S Power Button Replacement: Schritt 6, Bild 1 von 1
    • Use forceps to gently pry the PCB from the frame of the cassette player.
  7. Sony TC-WE825S Power Button Replacement: Schritt 7, Bild 1 von 3 Sony TC-WE825S Power Button Replacement: Schritt 7, Bild 2 von 3 Sony TC-WE825S Power Button Replacement: Schritt 7, Bild 3 von 3
    • Use a soldering iron to desolder the power switch’s terminals and connections. Remove the power switch, replace it, and solder it back together. Repeat these steps in reverse order to put the cassette player back together.
Abschluss
Cameron
108 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 669
