Zum Hauptinhalt wechseln
Sony TCM-919 Cassette-Corder Speaker Replacement
Was du brauchst
  1. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Battery Cover: Schritt 1, Bild 1 von 1
    • Turn the device around so that the back cover is facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Back Casing: Schritt 2, Bild 1 von 1
    • Remove the 5, 5.95mm screws as indicated in the picture.
  3. Sony TCM-919 Cassette-Corder Speaker Replacement, Desolder Speaker Wires: Schritt 3, Bild 1 von 2 Sony TCM-919 Cassette-Corder Speaker Replacement, Desolder Speaker Wires: Schritt 3, Bild 2 von 2
    • Look to the back of the top cover.
    • Desolder the two wires from the speaker.
  4. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Speaker: Schritt 4, Bild 1 von 2 Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Speaker: Schritt 4, Bild 2 von 2
    • Squeeze the two prongs holding the speaker in place and remove the metal piece.
    • Remove the speaker by gently lifting it up from the cover and pulling.
Abschluss
Baylor, Team 4-3, Williams Fall 2014 Mitglied von Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 494
