Einleitung
This guide will help users replace the battery on their Sony Tablet S. This requires a Phillips #0 and #000 screw driver, as well as a spudger and some plastic opening tools.
Was du brauchst
Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
Remove the five 4mm Phillips #000 screws.
Remove the two 5mm Phillips #000 screws holding the charger in place.
Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
