Einleitung
This guide shows how to remove/replace the RAM on the Sony VAIO VPCEE26FX laptop computer.
Was du brauchst
Slide the two tabs towards each other until the battery disconnects slightly from its position.
Carefully lift the battery out of its position away from the laptop.
Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
Push the two tabs holding the RAM sticks in place, away from each other.
The first RAM stick will pop up out of place. Remove it away from its position.
Push the two tabs holding the second RAM stick in, away from each other.
The second RAM stick will pop up out of place. Remove it away from its position.
