Zum Hauptinhalt wechseln
Sony VAIO VPCEC1M1E Keyboard Replacement
Was du brauchst
  1. Sony VAIO VPCEC1M1E Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the following color-coded screws:
    • These screws secure the RAM and hard drive covers, respectively.
    • These screws secure the optical drive to the lower case of the laptop.
    • The various other screws highlighted in the picture are unnecessary to remove and should be done at your own discretion.
  2. Sony VAIO VPCEC1M1E Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the following screws:
    • Five screws highlighted in orange.
    • Two screws highlighted in blue.
    • Pry the hard drive connector upwards from its socket on the logic board.
  3. Sony VAIO VPCEC1M1E Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Release the highlighted clips to remove the upper case of the keyboard.
  4. Sony VAIO VPCEC1M1E Keyboard Replacement: Schritt 4, Bild 1 von 3 Sony VAIO VPCEC1M1E Keyboard Replacement: Schritt 4, Bild 2 von 3 Sony VAIO VPCEC1M1E Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Flip up the retaining flap (highlighted in red) on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap and not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the laptop.
Ziellinie
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Stephan
199 Reputation
1 Anleitung geschrieben
3 Kommentare
Very useful, thank you. A real pain to do though without snapping the plastic tabs on the upper case.
Eddie B - Antwort
OMG... guys, you need just unscrew FOUR screws on the bottom (two orange circles on the same level that yellow sticker and two orange-circled screws in the middle of left and right side) and then pop the keyboard up with knife, etc, and disconnect the cable.
Paul G - Antwort
agree with Paul G. you don’t need to remove all the plastic case to change the keyboard
Pierret -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 30
Insgesamt: 23,020
