Einleitung
Repairing/replacing the DVD drive.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Turn the laptop upside down
The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
As shown by the arrow, slide the plastic cover up and then pull out and downwards.
You should now be able to pull the battery out.
Remove the four 16mm Phillips screws bordering the edge of the laptop, indicated here.
Remove the 4mm Phillips screw on the right rear side of the laptop next to the audio ports.
This will release the speaker grille.
Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
Carefully pull out the white electrical strip.
Remove the 4mm Phillips screw in the center (located to the left of the green strip).
Carefully pull the green strip straight up to disconnect it.
The keyboard can now be removed.
Remove the 4mm Phillips screw that connects the hard drive cage to the DVD drive.
Carefully remove the copper wire strip.
