Zum Hauptinhalt wechseln
Sony VAIO PCG-933A Floppy Disk Drive Replacement
  1. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Floppy Disk Drive Replacement: Schritt 2, Bild 1 von 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: Schritt 2, Bild 2 von 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: Schritt 2, Bild 3 von 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Floppy Disk Drive: Schritt 3, Bild 1 von 1
    • With the laptop facing you, turn the laptop upside down.
  4. Sony VAIO PCG-933A Floppy Disk Drive Replacement: Schritt 4, Bild 1 von 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: Schritt 4, Bild 2 von 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: Schritt 4, Bild 3 von 3
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
  5. Sony VAIO PCG-933A Floppy Disk Drive Replacement: Schritt 5, Bild 1 von 1
    • To replace, insert the new floppy disk drive with the wording facing down.
Abschluss
Sara Lillard
165 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 12-36, Maness Spring 2011 Mitglied von Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 2,021
