Zum Hauptinhalt wechseln
Sony VAIO SVE14AJ16L RAM Replacement
Was du brauchst
  1. Sony VAIO SVE14AJ16L RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Turn your laptop off before starting.
    • Turn the laptop upside down onto the closed lid so that the bottom is facing you.
  2. Sony VAIO SVE14AJ16L RAM Replacement: Schritt 2, Bild 1 von 2 Sony VAIO SVE14AJ16L RAM Replacement: Schritt 2, Bild 2 von 2
    • Locate and remove the lone screw on the RAM cover with a Phillips #0 head screw driver.
    • Carefully pry the RAM cover up.
    • There will be some resistance, so use strength and not speed to remove the cover.
  3. Sony VAIO SVE14AJ16L RAM Replacement: Schritt 3, Bild 1 von 3 Sony VAIO SVE14AJ16L RAM Replacement: Schritt 3, Bild 2 von 3 Sony VAIO SVE14AJ16L RAM Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    iFixit Opening Tool
    $1.99
    Kaufen
    • With the cover removed, peel back the black protective plastic to expose one of the two RAM sticks.
    • Make sure not to touch any part of the blue board itself, and only handle the stick from it's edges.
    • Gently, but firmly push back the two side anchors that hold in the RAM using either an iFixit Opening Tool or your fingernails.
  4. Sony VAIO SVE14AJ16L RAM Replacement: Schritt 4, Bild 1 von 2 Sony VAIO SVE14AJ16L RAM Replacement: Schritt 4, Bild 2 von 2
    • Once both anchors are released from the RAM stick, the stick will spring up at an angle
    • Finally, carefully pull the RAM stick away from the laptop at the same angle it is sitting at.
Abschluss
Dustin Smith
236 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 15
Insgesamt: 547
