Zum Hauptinhalt wechseln
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
Was du brauchst
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: Schritt 1, Bild 1 von 1
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: Schritt 5, Bild 1 von 2 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: Schritt 5, Bild 2 von 2
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Pham
207 Reputation
1 Anleitung geschrieben
2 Kommentare
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - Antwort
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 2,427
