Zum Hauptinhalt wechseln
Sony VAIO VGN-FW 590 Battery Replacement
Was du brauchst
  1. Sony VAIO VGN-FW 590 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Sony VAIO VGN-FW 590 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Battery Replacement: Schritt 2, Bild 1 von 2 Sony VAIO VGN-FW 590 Battery Replacement: Schritt 2, Bild 2 von 2
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Battery Replacement: Schritt 3, Bild 1 von 2 Sony VAIO VGN-FW 590 Battery Replacement: Schritt 3, Bild 2 von 2
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
Abschluss
Morton Wakeland
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 799
