Zum Hauptinhalt wechseln
Sony VAIO VGN-FW 590 Keyboard Key Replacement
Was du brauchst
  1. Sony VAIO VGN-FW 590 Keyboard Key Replacement, Keyboard Key: Schritt 1, Bild 1 von 1
    • Open your computer.
    • Make sure the computer is turned off.
  2. Sony VAIO VGN-FW 590 Keyboard Key Replacement: Schritt 2, Bild 1 von 1
    • Find the broken key.
    • The S key is our example though it is not broken.
  3. Sony VAIO VGN-FW 590 Keyboard Key Replacement: Schritt 3, Bild 1 von 2 Sony VAIO VGN-FW 590 Keyboard Key Replacement: Schritt 3, Bild 2 von 2
    • Insert the plastic spudger underneath the edge of the key.
    • Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
  4. Sony VAIO VGN-FW 590 Keyboard Key Replacement: Schritt 4, Bild 1 von 1
    • Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
    • Press the replacement key firmly in the center until it is completely depressed and attached to the key base.
  5. Sony VAIO VGN-FW 590 Keyboard Key Replacement: Schritt 5, Bild 1 von 1
    • Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
Abschluss
Congratulations! You have successfully replaced a key on your keyboard.
Jennifer Pache
304 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 1,492
