Einleitung
This guide will inform readers on how to safely uninstall the display of the Sony VAIO VPC-EB33FM laptop.
Was du brauchst
Power down the laptop by pressing the power button.
Turn the laptop onto its backside.
To release the battery, hold both the release button and the unlock button at the same time.
Remove the battery out from the notch while continuing to hold the release button.
Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
Grab the tab between your thumb and index finger.
Hold the hard drive securely in a horizontal position using your other hand.
Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
Pull the hard drive out.
If you need to remove the bracket from the hard drive, follow the next few steps:
Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
Lift the bracket off the hard drive.
Pull the two retaining arms away from the center of the RAM chip.
The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
Pull the RAM stick out of its socket.
To remove the second stick of RAM, repeat steps six and seven.
When installing RAM, make sure sticks are firmly in place or the computer will not register them.
Using a Phillips #00 screwdriver remove the following screws securing the back cover :
Two 3.8-mm screws
Two 8.9-mm screws
Twelve 7.75-mm screws
Using both hands separate the back cover by lifting from the back and working around the perimeter to release tabs.
Once the optical drive is removed, locate the keyboard ejection button and press down on it until you hear a snap.
Turn the laptop onto its frontside and unfold the laptop so the keyboard is fully visible.
Locate the area where the section of the keyboard was ejected.
Continue all the way around the keyboard until you can detach it from the laptop.
Turn the keyboard on its face and locate the green tape and the ribbon attachment.
Using the metal tweezer, remove only the green sticker.
Place the sticker at any location as long as you remember to use it for installing the keyboard.
Locate the black retaining arms.
Using the plastic opening tool, pull the retaining arms out.
Lift the retaining arms with the plastic opening tool at an angle so that the ribbon attachment can be pulled out.
Use a Phillips #1 screwdriver to remove the three 8.88-mm screws attached to the metal hinge at the corner of the laptop.
Repeat for the three screws on the opposite corner.
Gently pull out the base and place it with the keyboard side up under the display.
Use the spudger tool remove the plastic covers on the four corners of the display.
Use a Phillips #00 screwdriver to remove the four 5.75-mm screws under the plastic covers.
Use the plastic opening tool to separate the plastic front cover by wedging the tool along the seam.
Flip the laptop to the other side. If the front cover is still attached continue using the plastic opening tool to separate.
Carefully lift up the display. Completely detach the front plastic cover.
Use a Phillips #00 screwdriver to remove the four 5.65-mm screws on each bottom corner of the display.
Gently lift and pull the LCD screen up. The back of the screen has a connection attached by yellow tape.
Holding the silver flap underneath the yellow tape, pull up and disconnect the wire.
Place the LCD screen aside.
Grab a hold of the black plastic hinge and pull out completely.
Repeat for the other side.
Use a Phillips #00 screwdriver to remove the four 3.15-mm screws at top of the display.
Use the plastic opening tool to gently fold back all metal flaps at the beginnings and ends of wires.
Remove the tape holding a thin black and gray wire in place.
Use a plastic opening tool to loosen and remove the two connections at the top end of the wire with a thick silver covering.
Carefully pull the webcam and to remove it.
Fold back the metal flap under the webcam with the plastic opening tool.
2 weitere Personen haben diese Anleitung absolviert.
