Zum Hauptinhalt wechseln
Sony VAIO VPCEE26FX Optical Drive Replacement
Was du brauchst
  1. Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Optical Drive Replacement: Schritt 2, Bild 1 von 2 Sony VAIO VPCEE26FX Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 1
    • Use a JIS #0 screwdriver to remove the 4mm screw from its place.
  4. Sony VAIO VPCEE26FX Optical Drive Replacement: Schritt 4, Bild 1 von 2 Sony VAIO VPCEE26FX Optical Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the optical drive gently away from its holder on the laptop.
Abschluss
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S2-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S2G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 466
