Zum Hauptinhalt wechseln
Sony VAIO VPCEE26FX RAM Replacement
Was du brauchst
  1. Sony VAIO VPCEE26FX RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Sony VAIO VPCEE26FX RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX RAM Replacement: Schritt 2, Bild 1 von 2 Sony VAIO VPCEE26FX RAM Replacement: Schritt 2, Bild 2 von 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
    • This screw will not come out all the way, but will remain attached to the cover instead.
  4. Sony VAIO VPCEE26FX RAM Replacement: Schritt 4, Bild 1 von 1
    • Remove the cover which will reveal the two RAM sticks.
  5. Sony VAIO VPCEE26FX RAM Replacement: Schritt 5, Bild 1 von 3 Sony VAIO VPCEE26FX RAM Replacement: Schritt 5, Bild 2 von 3 Sony VAIO VPCEE26FX RAM Replacement: Schritt 5, Bild 3 von 3
    • Push the two tabs holding the RAM sticks in place, away from each other.
    • The first RAM stick will pop up out of place. Remove it away from its position.
  6. Sony VAIO VPCEE26FX RAM Replacement: Schritt 6, Bild 1 von 3 Sony VAIO VPCEE26FX RAM Replacement: Schritt 6, Bild 2 von 3 Sony VAIO VPCEE26FX RAM Replacement: Schritt 6, Bild 3 von 3
    • Push the two tabs holding the second RAM stick in, away from each other.
    • The second RAM stick will pop up out of place. Remove it away from its position.
Abschluss
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S2-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S2G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 1,425
