Einleitung
This will guide you in replacing the Media Board of a Sony Vaio VPCF 132FX
Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove all wires then flip the laptop
    • Remove all wires then flip the laptop
  2. Remove the battery Remove the battery
    • Remove the battery
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the screws and flip it back.
    • Remove the screws and flip it back.
  5. Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it. Slide from the sides towards the center. Slide from the sides towards the center.
    • Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it.
    • Slide from the sides towards the center.
  6. Gently remove the wire of the Power Button.
    • Gently remove the wire of the Power Button.
  7. Unlock the Lock. Unscrew the 3 Flat screws and remove the Media Board. You may skip this step if replacing the Power Button.
    • Unlock the Lock.
    • Unscrew the 3 Flat screws and remove the Media Board.
    • You may skip this step if replacing the Power Button.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
trickster
1.914 Reputation
11 Anleitungen geschrieben
What are the functions of the media board? My vaio vgn-fw170j won't power up (no LEDS on the power switch, or anywhere else, no fan, nothing). Verified that MoBo has 19.5 VDC on the board. Replaced MoBo and CPU, still no response. Since power button plugs into Media Board, figured it might be failed - any idea if this could be the cause?
course2kid - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 1,108
