Zum Hauptinhalt wechseln
Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance
Was du brauchst
  1. Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance, Filter: Schritt 1, Bild 1 von 2 Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance, Filter: Schritt 1, Bild 2 von 2
    • Turn off the projector and unplug it from the outlet or power source.
  2. Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 2, Bild 1 von 2 Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 2, Bild 2 von 2
    • Use a soft cloth or duster to gently dust off the surface of the filter cover on the back of the projector.
    • The filter cover is located on the top of the projector near the air intake vents.
  3. Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 3, Bild 1 von 1
    • Remove the filter cover by pushing in the two latches on either side of the filter protector.
    • Lift up gently and it should come out nice and smooth.
  4. Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 4, Bild 1 von 2 Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 4, Bild 2 von 2
    • Inspect the filter and look for any areas that are excessively dusty or dirty.
    • In this case, the filter is worn out and needs replacement.
  5. Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 5, Bild 1 von 1
    • If your filter is just dirty and only needs to be cleaned, start by gently tapping the filter over the garbage can to get all the loose dust off.
    • If additional cleaning is necessary, use a soft cloth to wash the filter with a mild detergent solution and let it dry in a shaded place.
  6. Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 6, Bild 1 von 3 Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 6, Bild 2 von 3 Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 6, Bild 3 von 3
    • Reattach the filter cover by pushing in the latches and placing the filter cover back where it was.
  7. Sony VPL-HW55ES-SXRD Filter Replacement and Maintenance: Schritt 7, Bild 1 von 1
    • Plug in the power cord of your projector and turn it on using the remote. Ensure that your image is now clear, with no dirt or dust streaks.
Abschluss
Hopefully, this guide has shown you how to replace or clean your filter within a very short amount of time. Make sure to do this at least once a month and your projector will be very happy!
Tyler Petty
145 Reputation
1 Anleitung geschrieben
Austin Community College, Team 1-9, Watkins Fall 2023 Mitglied von Austin Community College, Team 1-9, Watkins Fall 2023
AUSTINCC-WATKINS-F23S1G9
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 91
Insgesamt: 555
