Einleitung
Removing the back cover of your laptop is the first step in many repair processes. This guide will show you the quick and easy way to remove the back cover on your Sony Vaio Fit 13A laptop.
Was du brauchst
Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
2 weitere Personen haben diese Anleitung absolviert.
