Zum Hauptinhalt wechseln
Sony Vaio Fit 13A Battery Replacement
Was du brauchst
  1. Sony Vaio Fit 13A Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Sony Vaio Fit 13A Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Battery Replacement: Schritt 2, Bild 1 von 2 Sony Vaio Fit 13A Battery Replacement: Schritt 2, Bild 2 von 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Sony Vaio Fit 13A Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Locate and remove the ten 1mm Phillips #0 screws that are securing the battery in place.
  5. Sony Vaio Fit 13A Battery Replacement: Schritt 5, Bild 1 von 2 Sony Vaio Fit 13A Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the battery with the Plastic Opening Tool by placing the tool between the battery and the computer and cautiously prying it out.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Prange
527 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 21-19, Maness Winter 2015 Mitglied von Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 7,774
