Einleitung
If your computer is not powering on or holding a charge then you might need to replace your battery.
Was du brauchst
Begin by turning the laptop top-down on a flat surface.
Use a JIS #1 screwdriver to remove the 4 screws circled in red
Use a JIS #0 screwdriver to remove the 8 screws circled in orange
Remove the screws in the circled areas using the J0 Screwdriver to release the battery.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
