Zum Hauptinhalt wechseln
Sony Vaio Fit 13A SVF13NA1EL Battery Replacement
Was du brauchst
  1. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Begin by turning the laptop top-down on a flat surface.
    • Use a JIS #1 screwdriver to remove the 4 screws circled in red
    • Use a JIS #0 screwdriver to remove the 8 screws circled in orange
    • Many of these screws are located underneath the rubber pads on the device.
    • Keep track of the locations of the screws removed for ease of reassembly.
  2. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to carefully remove the back cover of the laptop.
    • Be careful when lifting around the ports and headphone jack to avoid causing damage to these components.
  3. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: Schritt 3, Bild 1 von 2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: Schritt 3, Bild 2 von 2
    • Lift up back cover to access internal components of the laptop.
  4. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the screws in the circled areas using the J0 Screwdriver to release the battery.
  5. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: Schritt 5, Bild 1 von 2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery from the laptop to remove.
    • Replace if necessary.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Olivia
605 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 70
Insgesamt: 3,987
