Zum Hauptinhalt wechseln
Sony Vaio Fit 13A SVF13NA1EL Fan Replacement
Was du brauchst
  1. Sony Vaio Fit 13A SVF13NA1EL Fan Replacement, Fan: Schritt 1, Bild 1 von 1
    • Begin by laying the laptop top-down on a flat surface.
    • Use a JIS #1 screwdriver to remove the 4 screws circled in red from the back cover.
    • Use a JIS #0 screwdriver to remove the 8 screws circled in orange.
    • Many of these screws are located underneath rubber pads on the device.
    • Keep track of the locations of the screws removed for ease of reassembly.
  2. Sony Vaio Fit 13A SVF13NA1EL Fan Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to carefully remove the back cover from the laptop.
    • Be careful when around the ports and headphone jack to avoid causing damage to these components.
  3. Sony Vaio Fit 13A SVF13NA1EL Fan Replacement: Schritt 3, Bild 1 von 2 Sony Vaio Fit 13A SVF13NA1EL Fan Replacement: Schritt 3, Bild 2 von 2
    • Lift up the back cover to access internal components of the laptop.
  4. Sony Vaio Fit 13A SVF13NA1EL Fan Replacement: Schritt 4, Bild 1 von 1
    • Dab isopropyl alcohol on a microfiber cloth and gently clean the fan blades and vents.
    • Follow steps one through three in reverse order to reassemble and test if the problem is solved.
    • If the problem is not resolved repeat steps one through three and continue on to step six.
  5. Sony Vaio Fit 13A SVF13NA1EL Fan Replacement: Schritt 6, Bild 1 von 1
    • Pull back the pieces of tape, and remove the 3 screws around the fan (red).
    • Remove the 3 screws surrounding the attached heat sink (orange) with the screwdriver.
  6. Sony Vaio Fit 13A SVF13NA1EL Fan Replacement: Schritt 7, Bild 1 von 2 Sony Vaio Fit 13A SVF13NA1EL Fan Replacement: Schritt 7, Bild 2 von 2
    • With the aid of a the opening tool, carefully unplug the fan connector.
    • Carefully lift out the old fan.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Olivia
605 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 23
Insgesamt: 2,724
