Zum Hauptinhalt wechseln
Sony Vaio Fit 13A Wireless Card Replacement
Was du brauchst
  1. Sony Vaio Fit 13A Wireless Card Replacement, Back Cover: Schritt 1, Bild 1 von 2 Sony Vaio Fit 13A Wireless Card Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Wireless Card Replacement: Schritt 2, Bild 1 von 2 Sony Vaio Fit 13A Wireless Card Replacement: Schritt 2, Bild 2 von 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: Schritt 4, Bild 1 von 3 Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: Schritt 4, Bild 2 von 3 Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to gently disconnect the two antenna cables.
  5. Sony Vaio Fit 13A Wireless Card Replacement: Schritt 5, Bild 1 von 2 Sony Vaio Fit 13A Wireless Card Replacement: Schritt 5, Bild 2 von 2
    • Locate and remove the single 1mm Phillips #0 screw that is securing the wireless card to the motherboard.
  6. Sony Vaio Fit 13A Wireless Card Replacement: Schritt 6, Bild 1 von 2 Sony Vaio Fit 13A Wireless Card Replacement: Schritt 6, Bild 2 von 2
    • Gently grasp wireless card with two fingers and pull away from motherboard to the left.
    • Do not pull the wireless card up when removing it. This could snap the connections.
Abschluss
Alex Prange
527 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 21-19, Maness Winter 2015 Mitglied von Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 1,846
