Zum Hauptinhalt wechseln
Sony Vaio Fit SVF14A190X Ram Replacement
Was du brauchst
  1. Sony Vaio Fit SVF14A190X Ram Replacement, Battery Replacement: Schritt 1, Bild 1 von 1
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 2, Bild 1 von 3 Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 2, Bild 2 von 3 Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 2, Bild 3 von 3
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 3, Bild 1 von 3 Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 3, Bild 2 von 3 Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 4, Bild 1 von 2 Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 4, Bild 2 von 2
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
  5. Sony Vaio Fit SVF14A190X Ram Replacement, RAM Replacement: Schritt 5, Bild 1 von 1
    • The RAM is a small rectangular component located on the opposite side of the lab top from where you pulled out the CD disc drive.
  6. Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 6, Bild 1 von 3 Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 6, Bild 2 von 3 Sony Vaio Fit SVF14A190X Ram Replacement: Schritt 6, Bild 3 von 3
    • Push down on the metal prongs encircled to allow the RAM component to spring up diagonally from the lab top.
    • When the RAM is sprung up, pull it out in the same direction it is currently at, to remove it from the lab top.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S11-G3, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G3, Cheng Spring 2018
USFT-CHENG-S18S11G3
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 345
