Einleitung
This guide will show you how to identify and properly remove the hard drive for the Sony Vaio Fit SVF15N26CXB. Use the project mat to keep the screws organized.
  1. Remove the following ten screws from the bottom case of the laptop: Two 6.5mm Phillips #00 Phillips screws.
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Use a plastic opening tool to separate the bottom cover from the laptop. Lift the lower cover and pull away from the laptop.
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Remove the eight Phillips #00 screws from the battery: Six 4.65mm screws. Two 4.65mm screws.
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Lift the battery up and pull it out of the laptop.
    • Lift the battery up and pull it out of the laptop.
  6. Remove the four 3.20mm Phillips #00 screws from the hard drive. Remove the four 3.20mm Phillips #00 screws from the hard drive.
    • Remove the four 3.20mm Phillips #00 screws from the hard drive.
  7. Use a spudger to flip up the black latch on the ZIF connectors. Pull the ribbon cables out of the ZIF connectors and fold them over the hard drive. Disconnect the hard drive and remove.
    • Use a spudger to flip up the black latch on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors and fold them over the hard drive.
    • Disconnect the hard drive and remove.
  8. Remove the four 3.70mm Phillips #00 screws from the hard drive mounting case. Carefully peel foil tray off of hard drive.
    • Remove the four 3.70mm Phillips #00 screws from the hard drive mounting case.
    • Carefully peel foil tray off of hard drive.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Althea McDavid
730 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S2-G4, Nance Spring 2018 Mitglied von USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 28
Insgesamt: 231
