Einleitung
The RAM is a small memory chip located within the device. This guide will show the user how to properly remove the Sony Vaio Fit SVF15N26CXB RAM memory chip. Use the project mat to keep the screws organized.
  1. Remove the following ten screws from the bottom case of the laptop:
    • Remove the following ten screws from the bottom case of the laptop:
      • Two 6.5mm Phillips #00 Phillips screws.
      • Four 8.95mm Phillips #00 screws.
      • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Use a plastic opening tool to separate the bottom cover from the laptop.
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
    • Remove the eight Phillips #00 screws from the battery:
      • Six 4.65mm screws.
      • Two 4.65mm screws.
    • Lift the battery up and pull it out of the laptop.
    • Gently push the silver heads outwards on either side of the RAM chip to release it from the slot.
    • Pull the RAM chip gently out of the slot.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Althea McDavid
Mitglied seit 14.02.2018
730 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S2-G4, Nance Spring 2018 Mitglied von USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 122
