Zum Hauptinhalt wechseln
Sony Vaio PCG-161L Speakers Replacement
Was du brauchst
  1. Sony Vaio PCG-161L Speakers Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Speakers Replacement: Schritt 2, Bild 1 von 2 Sony Vaio PCG-161L Speakers Replacement: Schritt 2, Bild 2 von 2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Speakers Replacement: Schritt 3, Bild 1 von 2 Sony Vaio PCG-161L Speakers Replacement: Schritt 3, Bild 2 von 2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Speakers Replacement, Speakers: Schritt 4, Bild 1 von 1
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Speakers Replacement: Schritt 5, Bild 1 von 1
    • Remove the 6 mm Phillips #0 screw on the left side of the battery that holds the casing to the device.
  6. Sony Vaio PCG-161L Speakers Replacement: Schritt 6, Bild 1 von 1
    • Turn the device upside down and remove the 6 mm Phillips #0 screw holding the casing to the device.
  7. Sony Vaio PCG-161L Speakers Replacement: Schritt 7, Bild 1 von 1
    • Remove the top casing by lifting up on the plastic exposing the two speakers.
  8. Sony Vaio PCG-161L Speakers Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 4 mm screws attaching the broken speaker to the casing.
    • Each speaker has two 4mm screws holding it to the casing. If you are removing both speakers, remove all four screws.
  9. Sony Vaio PCG-161L Speakers Replacement: Schritt 9, Bild 1 von 1
    • Disconnect the wire from the board by pulling the wire out of the harness.
    • These harnesses do not have any clips or tabs. Simply pull on the wire and it will come out of the harness.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Roman Alshehri
407 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G2, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S3-G2, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G2
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 297
