Einleitung
Are your speakers in your Sony Vaio PCG-161L no longer working? You can replace them in 30 minutes using this guide.
Was du brauchst
Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
Remove the 6 mm Phillips #0 screw on the left side of the battery that holds the casing to the device.
Turn the device upside down and remove the 6 mm Phillips #0 screw holding the casing to the device.
Eine weitere Person hat diese Anleitung absolviert.
