Zum Hauptinhalt wechseln
Sony Vaio PCG-3C2L Hard Drive Replacement
Was du brauchst
  1. Sony Vaio PCG-3C2L Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 2, Bild 1 von 2 Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 4, Bild 1 von 3 Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 4, Bild 2 von 3 Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Place the laptop so that the bottom is facing up.
  6. Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  7. Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 7, Bild 1 von 2 Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  8. Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 8, Bild 1 von 3 Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 8, Bild 2 von 3 Sony Vaio PCG-3C2L Hard Drive Replacement: Schritt 8, Bild 3 von 3
    • Remove the hard drive by carefully sliding it out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 708
