Zum Hauptinhalt wechseln
Sony Vaio PCG-3C2L RAM Replacement
Was du brauchst
  1. Sony Vaio PCG-3C2L RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L RAM Replacement: Schritt 2, Bild 1 von 2 Sony Vaio PCG-3C2L RAM Replacement: Schritt 2, Bild 2 von 2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L RAM Replacement: Schritt 3, Bild 1 von 1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L RAM Replacement: Schritt 4, Bild 1 von 3 Sony Vaio PCG-3C2L RAM Replacement: Schritt 4, Bild 2 von 3 Sony Vaio PCG-3C2L RAM Replacement: Schritt 4, Bild 3 von 3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • Flip the computer over so the bottom is facing up.
  6. Sony Vaio PCG-3C2L RAM Replacement: Schritt 6, Bild 1 von 2 Sony Vaio PCG-3C2L RAM Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the panel screw with a Phillips #0 screwdriver.
    • The screw is captive, it does not get removed from the panel.
    • Remove the panel from the laptop.
  7. Sony Vaio PCG-3C2L RAM Replacement: Schritt 7, Bild 1 von 3 Sony Vaio PCG-3C2L RAM Replacement: Schritt 7, Bild 2 von 3 Sony Vaio PCG-3C2L RAM Replacement: Schritt 7, Bild 3 von 3
    • Inside the panel there will be two green panels with black rectangles on top. This is the RAM.
    • To remove the RAM, use your fingers to press the metal tabs on the white holders outwards.
    • At this point, the green panel will flip up slightly.
  8. Sony Vaio PCG-3C2L RAM Replacement: Schritt 8, Bild 1 von 3 Sony Vaio PCG-3C2L RAM Replacement: Schritt 8, Bild 2 von 3 Sony Vaio PCG-3C2L RAM Replacement: Schritt 8, Bild 3 von 3
    • With the green panel flipped up, use your hands to remove the RAM.
    • Do the same thing for the second green panel.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 1,124
