Zum Hauptinhalt wechseln
Sony Vaio PCG-41216L Display Replacement
Was du brauchst
  1. Sony Vaio PCG-41216L Display Replacement, Display: Schritt 1, Bild 1 von 2 Sony Vaio PCG-41216L Display Replacement, Display: Schritt 1, Bild 2 von 2
    • Remove the covers for the two 3mm Phillips head screws at the base of the screen.
    • Make sure the device is unplugged and turned off before proceeding to minimize the possibility of electrical damage to the device.
  2. Sony Vaio PCG-41216L Display Replacement: Schritt 2, Bild 1 von 3 Sony Vaio PCG-41216L Display Replacement: Schritt 2, Bild 2 von 3 Sony Vaio PCG-41216L Display Replacement: Schritt 2, Bild 3 von 3
    • Use a metal spudger to separate the top cover on the back of the screen. It will be a long, thin plastic section that has the SONY logo in the middle of it. This enables the disassembly of the rest of the screen frame.
  3. Sony Vaio PCG-41216L Display Replacement: Schritt 3, Bild 1 von 2 Sony Vaio PCG-41216L Display Replacement: Schritt 3, Bild 2 von 2
    • Use the metal spudger on the sides of the frame to remove it from the screen.
    • Remove the four 3mm Phillips head screws that secure the screen to the exterior of the laptop.
  4. Sony Vaio PCG-41216L Display Replacement: Schritt 4, Bild 1 von 2 Sony Vaio PCG-41216L Display Replacement: Schritt 4, Bild 2 von 2
    • Carefully remove the screen from the supporting frame and lay it down on the keyboard of the laptop.
    • The wires connecting the screen to the body of the laptop will be exposed and fragile. It is important to proceed with caution.
  5. Sony Vaio PCG-41216L Display Replacement: Schritt 5, Bild 1 von 2 Sony Vaio PCG-41216L Display Replacement: Schritt 5, Bild 2 von 2
    • Locate the ribbon cable connecting the screen to the rest of the laptop.
    • It may be necessary to remove an adhesive seal in order to proceed.
  6. Sony Vaio PCG-41216L Display Replacement: Schritt 6, Bild 1 von 3 Sony Vaio PCG-41216L Display Replacement: Schritt 6, Bild 2 von 3 Sony Vaio PCG-41216L Display Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to remove the ribbon cable from the screen.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
content de voir qu'il ne faut pas démonter l arrière du pc pour retirer la broche de l'écran merci pour ce topic
Serge Wilhelmy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 26
Insgesamt: 895
