Einleitung
If the laptop is having boot up issues or a potentially failing drive, then use this guide to replace the hard drive.
Was du brauchst
Pull the hard drive out, then remove the 3mm Phillips screws that connect the hard drive to the casing.
Fast fertig!
Abschluss
