Zum Hauptinhalt wechseln
Sony Vaio PCG-41216L Network Card Replacement
Was du brauchst
  1. Sony Vaio PCG-41216L Network Card Replacement, Network Card: Schritt 1, Bild 1 von 2 Sony Vaio PCG-41216L Network Card Replacement, Network Card: Schritt 1, Bild 2 von 2
    • Flip the laptop over to begin the process.
    • Make sure the laptop is turned off and unplugged from the power cable.
  2. Sony Vaio PCG-41216L Network Card Replacement: Schritt 2, Bild 1 von 3 Sony Vaio PCG-41216L Network Card Replacement: Schritt 2, Bild 2 von 3 Sony Vaio PCG-41216L Network Card Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 7mm Phillips #1 screws holding the battery cover.
  3. Sony Vaio PCG-41216L Network Card Replacement: Schritt 3, Bild 1 von 3 Sony Vaio PCG-41216L Network Card Replacement: Schritt 3, Bild 2 von 3 Sony Vaio PCG-41216L Network Card Replacement: Schritt 3, Bild 3 von 3
    • Locate the networking card above the hard drive and next to the RAM.
    • Carefully pop out the two connection cables from the networking card.
  4. Sony Vaio PCG-41216L Network Card Replacement: Schritt 4, Bild 1 von 3 Sony Vaio PCG-41216L Network Card Replacement: Schritt 4, Bild 2 von 3 Sony Vaio PCG-41216L Network Card Replacement: Schritt 4, Bild 3 von 3
    • Remove the black tape to uncover the screw underneath.
    • Remove the 3mm Phillips head screw.
    • When loosening the screw, the network card will automatically lift itself to a diagonal position. This is normal.
  5. Sony Vaio PCG-41216L Network Card Replacement: Schritt 5, Bild 1 von 2 Sony Vaio PCG-41216L Network Card Replacement: Schritt 5, Bild 2 von 2
    • Pull the network card straight out in the direction it is resting in.
    • Reinsert the new network card diagonally and into the same position as the previous one.
    • To screw the new network card back into place, you will need to push the network card back down onto the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 624
